Bionic_Tuna
- May 1, 2003
When cooling a GPU and CPU, is it best to just do a series, with CPU out going to GPU in, or Y split it from the radiator and go separately to CPU and GPU, then back together to the res?
Bionic_Tuna said:When cooling a GPU and CPU, is it best to just do a series, with CPU out going to GPU in, or Y split it from the radiator and go separately to CPU and GPU, then back together to the res?
RickyJ said:You would have to make sure that there would be enough water going to each block. If one of the blocks was pretty restrictive, and the other was free-flowing, then the restrictive one wouldn't get any water (barely any). Water works like electricity here, it moves along the path of least resistance. You would have to put in restricting valves to control the flow.
I've read on here that the temperature difference before and after a block is very small (since there's so much moving through the blocks), so there seems to be no point to a parallel setup here. The slight difference in water temps to the GPU doesn't seem to be worth the hassle. Besides, you would actually be pushing less water past each block, potentially lowering their cooling effectiveness.![]()
TheArchitect said:Don't forget that like electricity, with a GPU in series will make there be less flow through the system as well. So it depends on how balanced the two coolers are... if they are about the same I'd say go parrallel and get higher total flow unless the most restrictive element is your radiator by far. It really depends on your system and components.
Either way, you're looking at reduced flow through your CPU block.
