Serial Port? Uses?
well.....i have a cable that has a female 9 pin connector at one end, and a headphone pin at the other....what in the world would this be used for?
The port could also be used for mobile phones, dex drives. As for your cable, not sure. :confused:
I have a digital camera that uses a cable like that..
9pin to mini stereo thing
my TI86 uses a wire like that.. 9pin to serial headphone like connector..
I know those ancient organizers use taht port also.
(hides soon to be gray hair)
Serial ports were used for the following:
PC to PC connections (AKA direct cable connection, slower than the first gen P4)
Older digital Cameras
Dex drive (A device that allowed you to save Playstation memory card data to your PC)
Medical equiptment (Still used to this day)
Mice
External Modems
Most older reciept and label printers
POS terminals
Older bar code scanners
Touch screens (older)
Older TI graphing calculators for data link to a PC for backups, new program installations etc (Probably what the cable you mentioned is for)
Remote controls (You can find the plans to build a receiver for IR remotes online easily enough, done it myself!)
Older UPSes (battery backups) for unattended shutdowns during power loss
Remote Terminals (these are really old school mainframe terminals. Some modern networking equipment still use serial consoles for emergancy usage)
Older Palm handhelds for synconizing with the PC
Modern day times you'll be rather hard pressed to actually need a serial port. Almost everything is USB now.
That's mine.
eighteen_psi said:
That's mine.
Also good for newer UPS's. I have my Belkin 1200VA on a Serial port. Frees up a USB port, plus I like the security of the screw down connector.
Probably an old school PDA
Console port to a network device (e.g., Cisco switch, Netgear wireless router)
Can anyone tell me the uses for Serial Ports? ie Com A ports.
To communicate with RS232 devices...not everyone uses a computer as a toy...
I have 4 RS232 ports that are used to talk to multiple RS232, RS485 via converter and serial modbus devices.
Your power utility company will probably be using them too, most protective relays use RS232...This is a transmission relay, it has 4 RS232 serial ports, one ethernet adapter as an option.
MD
Ah the good ol days of Doom via serial cable...talk about a pain to setup.
bauds, parity, getting special handshake adapters...all in the name of fun
My CyberPower UPS uses a serial to communicate from the UPS to the software :rolleyes: I don't like using it, but ... eh.
every machine shop in the world uses the com ports to communicate with their cnc machinery
