Would it be possible to do a simple mod so I could use a second PSU to power my lights/fans?
The answer, yes, it's not so hard after all. I don't know if any has done this in the past, but here's how I see it working:
What I used:
A Box Knife (or any other sharp knife for stripping wires)
A PCI On/Off switch that comes with most cathodes
An old PSU. (maybe a Micro-ATX PSU would be better space wise)
That's about it.
Step 1: Cut away the unneeded wiring from the PCI switch.
Step 2: Strip the ends of the two wires left, about a quarter inch back.
Step 3: Twist the exposed wiring well, making a point.
Step 4: Insert these wires into the third and forth holes on the 20/24 pin connector (where counting from left to right, and the clip is facing away from you)
Step 5: (I didn't do this yet, dunno if I will actually use this mod) secure the wires in place.
All done
(sorry for the blur)
Flipping the switch turns the PSU on and off, takes a second or two to power down completely though.
I hooked up a UV Cathode to it and layed some UV stuff over it for "bling" purposes.
What I used:
That's about it.
All done
