Separate Raid controller for a server ?
sam-sgc
Hi,
Is it worth it to place my RAID-10 array on a separate RAID Controller instead of using the one that came with my server.
I'm looking to buy a new server with 2 raid arrays. Raid-1 for the O/S and RAID-10 of 4 disks for some various files and some database.
Do you think each array should have it's own controller ?
Thanks
Let me know if you need more details
-Sammy
It's a Dell powerEdge 2900
The integrated controller is a PERC 5/i
the add-on controller is a PERC 5/E ( Pci-E Raid)
Thanks
Sam
Ideally, the more controller channels the array has, the better the through put will be.
If the two array is on 5 disks, the advange of two controller is be little unless the raid-10 array has a large amount activity. If that is the case, then do get the extra controller.
Keith
How can I find out if my single controller is causing a bottleneck ?
