7700K should be okay without OC, but louder/hotter, but I believe with Titan X Pascal/1080TI you'll have to use the case only in vertical position on a stand and you might still need to ramp up the fan curve like Linus did to get the full performance out of the card.
I'm also not sure if getting 1080TI won't be unnecessary overpaying for the GPU since in Ryzen 1700 vs 7700K benchmarks overclocked i7 was pretty much balanced in full load with GTX1080 on Battlefield 1 (both GPU and CPU had 95~98% loads). This means that without OC you're definitely going to bottleneck 1080TI with your CPU if you're not going for 4K.
Actually I'm curious about this too. The last two pictures show the internal GPU filters, and that they'll fit that way. I'm assuming that won't be the case for the vents over the motherboard, especially since the low clearance over the PSU? It's only a slight bummer, that adding the filter externally over the motherboard will slightly take away from the plain white aesthetics of my case.This might sound like a silly question but would I be able to mount these magnetic filters inside my white sentry?
EDIT: nvm i saw the last two pics
I can see you haven't been paying attention to our twitter
In vertical position you can mount all four filters externally. Note the fact that one of the exhaust filters has cutouts for the vertical stand locking bolts.
In horizontal position the GPU filter should be mounted on the inside because the magnetic frame is thick enough to cut the gap between the case and the surface it's standing on on the bottom of the case by almost half limiting the fresh air access to the GPU.
When only using case horizontally you could be also using the rectangular filter without cutouts for vertical stand bolts on the CPU/PSU side.
Also, since I believe those filters are directional meaning they are optimised for the airflow in one direction, you might want to install the exhaust filter in opposite way, internally inside the GPU bracket when using blower style GPU because it will suck air from the side as well. I think there should be no problem in ordering the set with this filter optimised for opposite direction since they are taking custom orders as well.
You won't have to buy all 5 filters because DEMCifilter sells their filters either as a package or piece by piece.
I understand you explained it before, but I'd prefer to keep the filters inside to keep the cleaner exterior look. I was saying I'm imagining you simply can't install the filter over the motherboard internally due to clearance. You mentioned you can install the GPU filters internally, I get why that is. I only brought it up because I remember I believe it was Linus saying he had to remove the fan grille on his PSU to get clearance which is why I am guessing there isn't clearance internally for the filter. No biggie though.I think I have explained this already
Sad news all. The results of my Dynatron R15 mounted with zip ties and a copper shim with paste on both sides is less than ideal. I wasn't sure how well it would perform with limited mounting pressure and grease on both sides of this shim...
~80C during CPU-z stress was satisfactory, but that's when the GPU is idle. I get ~90C in a heavy gaming load in Crysis 3 (ultra with 1440p rez) with my 7700k (stock) with a Zotac Amp Extreme GTX 1080. Now that both CPU and GPU are stressed, the hot air the GPU spews into this open style case I currently have which represents the best scenario for an open style 1080Ti in Sentry is too hot.
So, my question to all of you now is... Have you tested the Thermolab LP53 against the Dynatron K129? Do you think those will get better performance than my current setup? I will mount the same Noctua NF-A9x14 fan I have on there now. If this is the current best that I can get it looks like I'll be forced to get a founders edition 1080Ti.
http://www.cooltek.de/en/cpu-cooler/powered-by-thermolab/128/lp53
http://www.dynatron-corp.com/?product=k129
Thanks! That's what I was looking for! And also what I figured would be the case. I'll probably just try filter-less for the most part.Ok, so no, you cannot install the filter internally on the PSU/CPU side - case cover is lying directly on the PSU and there's not enough space for the filter with magnet frame to be mounted on the side.
Also the target for the filters was to be mounted externally because people that asked about filters mostly wanted them easily removable without opening the case. The only problem was with thick frame in desktop position where case feet are pretty short so we designed additional filter for internal mounting under the GPU.
If you want to use the filters internally on the psu side, then you should pick a generic 0.5mm filter without magnetic frame to lay directly on the PSU and pick some fitting magnetic frame for the motherboard area, but remember not to put magnets near hard drives. As for the side/exhaust, I have no solution for mounting a filter on that side properly as this side slides directly on the edge of motherboard tray and this edge is directly around the edge of the vents. This means if you were to put a magnet frame there, you would block off significant part of the exhaust.
1) You know that this card, the Zotac Amp Extreme GTX 1080 won't fit inside Sentry? And there's a good reason for that - this card takes up to 270W while the reference TDP of 1080 is 180W. Linus tested 250W Titan X Pascal and it didn't have perfect temps.
2) What case are you using now? How do you decide if your tests are relevant for Sentry?
3) We haven't tested those coolers. With your current setup ~80C during stress test is a proper temperature for 95W TDP CPU on a low profile cooler. Changing this to a different low profile cooler won't do anything if motherboard area is filled with air heated by the back of the card or simply exhausted by it.
I think Ill go for a cheap system: G4560, RX470, 8 GB RAM, 250 or 500 GB m.2 SSD. I go more by silence as for maximum specs, it will do for my current needs.
Thís is a German site
https://www.computerbase.de/thema/prozessor/rangliste/#diagramm-gesamtrating-spiele-full-hd
You can compare CPU performance by absolute performance, including several bechmarks, or you can just compare them by gaming performance. Here the Pentiums performance is 79% of the 7700K.
Makes good sense to me.
Pentiums are shockingly strong gamers, nowadays. Are they going to be able to run triple A games? Not well. But how many of us really spend most of our time playing AAA games?
My time sinks are Civilization, Rocket League, and an ancient, dual threaded MMO. 90% of the time, I'd be perfectly set using my HTPC.
(But then, I do enjoy my flashy games too. I just hope we get a super popular fps on the pc soonish - everything seems to be empty.)
Edit: personally, I'm probably putting an i3-7350k in my Sentry to start out with. It's an unlocked 60w part, so heat is less of an issue and with a good enough cooler, some overclocking is possible.
I'm heavily into emulation, so a lower TDP part that I can make have better single core performance is highly appealing... Plus it's way, way cheaper than an i7 and I haven't saved enough for a full system overhaul yet.
Will there be any other way to purchase one of these cases in the future? I got wind of this too late to reserve one on Indiegogo.
We were planning on making up to 5000 units in total for the backers but since we've got a bit above 1000 we should start figuring out retail to be sooner than September, hopefully June or July.
Yeah, we know there are few things that didn't go perfectly with our marketing. But what you're talking about was virtually impossible for us before the campaign and until we deliver the product, such sites are not treating us seriously.
Obviously in the heat of campaign there was some interest, but except for that limited time we weren't able to reach out to them.
We also know we have to ship more review samples to media, production quality this time when coming into retail.
any idea on cooler that fits am4 and sentry guys ? BTW: has biostar released there mini itx am4 board yet ?
Out of curiosity, what do you mean they weren't treating you seriously? Just not returning emails, or...?
Do you figure it has to do with not having a "finished" product, or simply with not having the money and volume that, say, NZXT has?
I think a lot of the reason you didn't fly past that 5000 unit mark is because of marketing. I've talked to a lot of people who aren't into SFF, see the Sentry / Dan A4 and what they can hold, and instantly go, "that's awesome, I want one."
Honestly, it kind of baffles me. There are a TON of posts on articles about huge, crappy new "SFF" cases, and about every fifth one is bemoaning the offerings out there and wishing their was a better solution. (Cough. Cough.)
When you guys make it to retail, I would highly consider sending review units (or even just press releases) to places like Tom's Hardware, Smallformfactor.net, or Bit-tech. At this point you don't need more reviews of how stinking amazing the Sentry is, you just need more people who know it exists.![]()
SFF and Bit-Tech I see occasionally but those are still pretty niche (most of the folks there who want an SFF case probably have one already). Take Arstechnica or Anandtech, that's where you hit the folks with disposable income and very wide ranging interest in technology.
