Corummo
- Jun 5, 2016
Furthermore, I'd add to the cons: the only reliable riser for that kind of config is the one from 3M, that costs a lot (about 90€ at the moment of writing).
Yeah .... that's why the Dan case is so ridiculously expensive.Furthermore, I'd add to the cons: the only reliable riser for that kind of config is the one from 3M, that costs a lot (about 90€ at the moment of writing).
They need to be reference size to fit into the case, as far as I can tell, so most of the bigger cards are not going to fit. I'm going with the MSI Aero OC GTX 1080 because it's reference size, but has a better blower cooler than the stock card. It's going for about $640 if you can find it. Most of these other cards are ginormous. So yeah ... either the stock NVIDIA cards or third-party stock-sized cards. There might be more wiggle room, but it would have to be confirmed by someone else.
The blower coolers on the stock NVIDIA cards are garbage and MSI has traditionally had better ones, so I'm more going on an assumption based on their reputation, but I could be wrong.What makes you say that the MSI Aero has a better blower cooler? My assumption was it was functionally the same as any other blower style cooler, just made with a plastic shroud to reduce the cost compared to Nvidia's version.
I can't find any reviews of it online yet, but if the cooler really is superior to the reference (excuse me, "founders') edition, that'd be a valuable thing for this thread to know.
Also, just in case any english-learners come across this thread, there are still plenty of custom coolers that fit within this case's specifications... just not many of the flagship coolers.
The MSI Aero is their slim card, so it will fit for sure. Been eyeing that card specifically for this case. It's 269 mm x 111 mm x 35 mm. It's not one of the monstrosities that ASUS/GB have.If you want to buy the card now I'd say to go for a blower style like TheFragile said - it's the safest choice if you're not sure how to pick the card depending on its size, just make sure that those ain't the fancy asus/gigabyte oversized blowers.
Wow. That thing is gigantic. But if it could be confirmed that it fits, I might get that instead. But do you think a card like that with 3 fans is better than a blower card for this particular style case? The STRIX is OC'd to boost around 2 GHz right out of the box, which is nice. The Aero is around 1.7 ish.Surprisingly asus strix might fit, but we'll have to get that checked somehow.
Do you think the MSI GTX 980 Ti Gaming 6G would fit into this case? I just got a ridiculous deal on this card and wondering if I should keep it for this case. If it won't fit I'll just sell it. It's 10.59" x 5.51" x 3.1" or 268 mm x 140 mm x 81 mm. Isn't this a bit too thick? I think your site says the entire case is 2.5" wide so this would definitely not fit if that's the case. The ASUS Strix is gigantic but it's not even 2 inches thick.
I'm just saying it adds to the cost of the case, among many things. The case is €230 ($258 USD).Hmmm, i didn't read this before...
You mean, when ordering 1500 pcs of 3M riser for almost 1500 ordered Dan-A4 cases, PCI-E riser still costs 90€? So if You accidentally damage Your riser what would be the cost of 1 pcs of this 3M riser? 200€? I don't get it. When You order only 1 pcs of something then it can be expensive. But when You order 1000 pcs then in most situations you'll get a discount from the manufacturer. I don't understand why everyone think that DanA4 is so ultra-expensive, because of the price of PCI-E Riser...
I think 90€ is a price for this riser when you are a simple customer and you need only 1 pcs. But if you will order 100, 500, 1000 or more, then the price should drop dramatically (maybe even divided by 3 or 4).
I'm not following dondan topic, so maybe i'm missing something. Correct me if i'm wrong, but i don't believe that nearly half of the pc-case price would be a cost of the riser (especially in a mass production/order).
I signed up specifically to show my support for this project. This looks like an awesome case and I'd definitely order one as soon as the pre-orders open!
The build I have in mind is X99, probably with a 6900k/6850k plus something like a 1070 or 1080. Do you think temps will still be okay with a 140w CPU instead of a 90w+ one? I'm not planning on OC'ing either the GPU or CPU.
Edit: I did some searching myself and couldn't find a ILM narrow cooler that would fit the case. Does one exist?
You probably shouldn't based on the TDP of the 6900k/5850k is 40w over the Cryorig C7.
Also might I suggest the 6700k or even the 6700 "non k" on the H/Z170 motherboard? The only real gain for gaming on a 6900k CPU over a 6700k is more PCI lanes for more than 2 SLI which you wont even touch in this case or many others and "future proofing" due to the additional cores and threads for DX12 and on. Plus a 1100 USD price tag vs 315 USD is madness as well as the cost of the X99 boards are not cheap compared to the H/Z170 boards so the price for performance is just not there with X99.
The primary purpose is to run simulation models where 6/8-core comes in handy. From the benchmarks I've seen I'm expecting a 40-60% performance boost from the 6700k if neither is OC'd. Gaming is of secondary importance and if it runs too hot with the GPU under load, I'm open to underclocking the CPU when I game...
Based on benchmarks with the A4-sfx it seems that with a bit of customization a 5820k might work under similar conditions (48mm max cooler, ~80c with Prime95). But I agree, even that is pushing things a bit far.
this is not the case you are looking for. seriously, its not built for it. to get a big enough cooler for that chip you have to cut a hole in the side and let it stick out or maybe external water cooling.The primary purpose is to run simulation models where 6/8-core comes in handy. From the benchmarks I've seen I'm expecting a 40-60% performance boost from the 6700k if neither is OC'd. Gaming is of secondary importance and if it runs too hot with the GPU under load, I'm open to underclocking the CPU when I game...
It's cool that dondan did those tests but he didn't log the clocks. I think it's the same with the gpu tests - he didn't log clocks in those either. The problem is that cpu might be hitting the target temps in the same way as gpu's do and throttle. Also note that when you undervolt that might mean reducing the power limit to the cpu which ends up cutting the clocks as well. Also unless you've got kick-ass cooling keeping really low temps undervolting might make the cpu unstable on various loads even when it passes prolonged stress tests.
Additionally note that A4 has direct escape of hot air above the motherboard while Sentry in vertical position on a stand doesn't, so it would go up and heat up gpu and disks if not dissipated fast enough. We haven't done tests with such power hungry cpu's though, so you never really know what happens until you check it.
That said, I'd still like to see it happen![]()
Hello everyone!, I'm new to this forum but I've been keeping an eye on this case's progress for a while now
I built a mini-itx system for myself recently with the following specs:
CPU - Intel i7 6700K
GPU - MSI Gaming 960 2GB (I plan on upgrading to the RX480 if it benches well)
Motherboard - Gigabyte GA-Z170N Gaming 5 (mini itx)
RAM - Kingston HyperX 16GB @ 2400Mhz
SSD - OCZ Trion 150 240GB
PSU - Corsair SF450 SFX
Now the reason why I listed this is because I'm also using the Cryorig C7 cooler but with the 6700K and in the Silverstone RVZ02, I'm happy to report absolutely no throttling (and this is with the filters on), my room temperature nearly always sits at around 22c-23c degrees, the 6700k's temps are as follows:
The first "At Load" results are with AIDA64 Extreme's stability test and with everything in the system stressed including the FPU (on the CPU), GPU and SSD. Temps were recorded using CPUID HW Monitor and AIDA64 itself.
At Load:
81c - Hottest CPU Core (for barely a second)
79c - Hottest CPU Package
75c - Average CPU Temperature
At Idle:
41c - Hottest CPU Core (again for a fraction of a second)
39c - Hottest CPU Package
37c - Average CPU Temperature
In Game (The Witcher 3 ultra settings, hairworks off @ 1080p, played for 20min)
75c - Hottest CPU Core
74c - Hottest CPU Package
69c - Average CPU Temperature
All these temps are with my custom relaxed CPU fan curve, the fan sits at around 30-50% (very quite) until the CPU hits 65c then the fans spin up to 60-75% until the CPU hits 80c then it spins at 100%. (even at 100%, it's still quieter than my PS4, GPU included)
So, sorry for the long post but the reason for it is because I was originally planning to build this PC in the Sentry Case (and I still do when it releases), but for now I built the PC using the RVZ02 and I am surprised at the temperatures considering I'm using the 6700K unlocked CPU and it's running at it's full capabilities with absolutely no throttling whatsoever.
Well there you go, just in case anyone was wondering, yes you definitely can use the 6700K with the Cryorig C7 in a small mini-itx (RVZ02) which means you should have almost the same scenario in the sentry with no performance loss and reasonable temps, although I do recommend using a custom fan curve as the default is a little over aggressive.
If anyone wants me to run some specific tests as well I would be glad to.
Wow glad you posted about your build and how it applies here. I've been thinking about upgrading to the 6700k for a bit, coming from a 2600, mostly for the nuances and availability of ITX 170 motherboards, but also because I want to. So I'm happy to see good temps with the C7 on your 6700k in that case.
Time will tell what limits are possible in the Sentry!
A couple of things you should know first:
The Cryorig C7 is nicely built and packaged but it doesn't like my motherboard (GA-Z170N Gaming 5) very much, When installing the cooler the back plate that was included refused to sit flush with the back of the motherboard and even after flexing it a little the threads on the screws wouldn't reach the backplate. It's good that they include 4 rubber grommets in case that happens though, so I had to use those instead of the backplate.
Secondly the step above the coolers bottom plate (it's hard to see in images but there is a step above the coolers bottom plate) actually presses on the motherboards power phases. I tried orientating the cooler 90° but it's actually worse at that angle. It manages to fit anyway but just barely and about 1-2mm of that step on the cooler is pressing down on 1 power phase with the same amount of pressure that's on the CPU, I don't like it but I haven't had any problems.
All in all it's a good cooler, but I can't really recommended it with my exact motherboard (which is annoying because it's a fantastic motherboard).
Also I forgot to mention I'm using Noctus NT-H1 thermal compound (they do include some of their own brand thermal compound with the cooler though), so that might have a little effect on my temps.
Looks like I'll be going with a Noctua cooler instead. Don't feel like bending anything to make it fit.
