Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You have to enable the option for that, you can do so in your User CP, it's not set to save them by default.
Click on User CP on the top left of this screen, then click Edit Options, then scroll down slightly, you'll see the option to save all Sent Messages. Check the box, and save your changes and you're done.
