I have a Sony MDR-CD480 head set that is about 14 years old and starting to fall apart. So I just ordered the Sennheiser PC350's on sale for $70 off as a replacement. Knowing that they have an impedance of 150 ohms I was initially a bit concerned. The sound card I have is the Asus Xonar DG with built in head phone amplifier which is supposed to be optimized for 32-150 ohms. So far, so good. Except I am also using the Logitech Z5500 speakers and control pod. The control pod is plugged into the sound card using the optical connection and the PC350's will be plugged into the control pod.
So the question is, does connecting thru the control pod affect the way the sound card amplifier works? Can I expect to have any issues or is all good? Also, one reviewer recommended using "pink noise" to break them in. What is pink noise and is it necessary? Thanks.
