Senn HD555 Revision?
TheBlueChanell
Hello. I was looking at the specs of the HD555. I saw that they had 120ohm impedence. I then checked senns sight, and It lists it @ 50ohm? Did they update the HD555? Also, someone on newegg brought this up too. if so, would this shorten the gap between the HD555 and HD595?
They revised the entire line 515/555/595. Initial shipments were 120 ohm, now all are made in 50 ohm. Conclusions as to which sounds better are mixed and generally inconclusive as far as I know.
