semirigid headset mic missing
achalas
any place i can buy a short stereo-mini (3.5mm) type mic, short, semirigid (e.g. 6" length extension) ? I have a headset but the mic became detached and is missing. I see a similar concept (for example) with this shure mic (http://www.shure.com/americas/products/microphones/beta/beta-98hc-instrument-microphone), except right-angle connector won't work, and what's needed here is something for pedestrian gaming.
any suggestions are appreciated,
thanks
I used a Zalman MIC-1 for years without issue, which you can get for as little as $12 if cost a big issue at the moment (Amazon). No-frills clip-on mic.
A clip on mic like the zalman would be your most cost effective solution. It isn't perfect but should work well emough.
