Semi-Random system rebooting
ozno
So I've had this system for just under 2 years and it has started crashing while playing games with the machine_check_exception. It has never reset itself while just idling or doing desktop applications, only while running games. Everything in the system was bought/assembled around sept. 2005 except for the power supply which I had to replace this February.
Celeron D 2.8 Mhz
ASUS P5RD1-V MB
1 gig PQI PC3200
160gig seagate SATA
ati x700PRO video card
The power supplies I use are always 450-500 watt name brand (whoever has rebates that week). I never use the top end hardware, but I stay away from generic parts.
My first thought was the RAM, so I've ran memtest86 extensively off the bootable CD ISO. If both 512 sticks are in the system it reboots during the test before it finishes, but no memory errors ever pop up before then. This happens consistantly, I've never had memtest finish with both sticks of RAM in the system. If I use just one of the 512 sticks at a time, it always passes. I've tried both 512 sticks individually in a number of sockets to rule out bad memory sockets as the issue. I've also preformed these tests after upping the DDR voltage from the default incase that was the issue.
Also because the system can reliably reset during memtest86 which does not use any 3d graphics, I also tend to think it may not be the vid card.
The temps for the system are within the normal range of running temps. CPU always hovers around 46 C according to the MB monitor. The CPU fan/heatsink are attached and working along with 2 case fans and the video card fan.
Because the system resets reliably while running memtest86 with both 512 sticks in it, but has never reset while running the exact same test with only one of the sticks I don't think it is a problem with the disk drive.
This leaves the MB/CPU/power supply issue perhaps, but I'm running out of ideas for testing. I'd hate to think that the power supply is dying so quickly after just 5 months, but it certainly is a possiblity. On the other hand every power supply I've had go out doesn't limp along slowly degenerating, but rather goes out quickly in a blaze of glory.
If anyone has any suggestions or recommendations, I would appreciate it.
Yeah excellent idea, I feel like an idiot for not having come up with that myself. Ran the tests with each stick in a different channel and it ran memtest86 no reboot, no errors. My guess at this point is that something on the MB related to dual channel functioning is shorted, which I am now side stepping by running each stick in its own channel. Thanks again so much, later today I'll do some testing on games and see how it goes.
Also chalk up one more reason for always buying MBs with 4 RAM slots.
