Semi-Fast 19" 8bit LCD?
Jpitzo
So, I'm in the market for a 19" LCD. I'm not too much of a gamer but I do watch a lot of movies and such so I would like the refresh rate to be moderately low ( < 20ms ). However, accurate color reproduction is essential ( 8bit panel ). Is there any happy medium between the two?
ouch anything in a more moderate price range....or a site that will tell me if a panel is 8bit or not
In general, all you have to do is look at a monitor's specs.
16.7 MIllion colors = 8bit
16.2 Million Colors = 256k colors with dithering = 6bit
Most Dell flat panels above 17" are 8 bit, but might have higher response times than you might be looking for. I personally use an 8bit 25ms LCD and am not bothered by the ghosting much, although I do notice in FPS games. Once you get used to an LCD, you don't really notice.
For movies, however, you really shouldn't need anything below 16ms...but that is a matter of taste.
EDIT: some options:
http://www.newegg.com/Product/Product.asp?Item=N82E16824176047
http://www.newegg.com/Product/Product.asp?Item=N82E16824021034
http://www.newegg.com/Product/Product.asp?Item=N82E16824021019
http://www.newegg.com/Product/Product.asp?Item=N82E16824179018
http://www.newegg.com/Product/Product.asp?Item=N82E16824168005
http://www.newegg.com/Product/Product.asp?Item=N82E16824179014
http://www.newegg.com/Product/Product.asp?Item=N82E16824001069
