Semi cheap case suggestions?
Muppet
Looking into building a WC setup and need a case with enough room to house it all, I want to put the Rad on the outside, prefer the room to mount it on the back of the case so the air is outside of the case. Anyone have any suggestions that won't kill my wallet?
what price range would kill your wallet?
I'm using the 570 and its got a ton of room, and is set up for water cooling with minimal modding price is on the high side but there are others far beyond it in price...
slightly smaller is the first gen of the same case.
That is a nice case, if I got a 2 120 rad, that would go fine on the back side of that case right?
Not sure where most mount their rads, only downside I see is then hot air from the case would then be blowing over the rad, but with 2 120's I don't assume there will be much heat comeing from inside the case anyways.
