Selling WC gear
Status
Not open for further replies.
Aris
ive had it for over a year straight, running almost 24/7 in a completely closed loop.
Maze 3 cpu WB w/ acrylic top
Dtek customs Pro 120 radiator.
(it has a 120mm fan shroud on both sides for an optimal push/pull configuration)
Hydor L35 pump
1/2" ID Tygon Tubing
im gunna keep the papst fans currently on the rad. but i have some panaflo 120mm fans that i dont use anymore that i can sell with this.
3x 120mm Panaflo H1A's
1x 120mm Panaflo M1A
they do have tails. but they have been clipped so that only bare wire leads are left, i had them in a baybus.
i havnt disassymbled it yet. i will prolly do that some time this week or next weekend. the water hasnt been changed since i put it together over a year ago (last November). The water has changed from its original bright pink (cause of the water wetter) to a browning color. it prolly just needs to be cleaned out and fresh water put back in it. i dont see any growth of any kind in the system, i can still very clearly see the water running through the CPU waterblock through the acrylic top.
never had any leaks, its a completely closed loop system (ie: no fill tube or rez). and i used (i think) a 10:1 ratio of water/water wetter.
id prefer to sell it all together instead of piece by piece. i havnt really priced all of it out, i just sorta wanted to throw it out their to see if their was any interest in it.
Status
