Selling 6tb HDD 2morrow - Need Fast secure format - ASAP
Discussion in 'SSDs & Data Storage' started by Dracarys, Apr 15, 2019.
  1. Dracarys
    Dracarys n00b
    56
    Dec 16, 2014
    Hello,
    So started the Dban software and began the Nuke, it would literally take days to erase everything securely.
    Then, I started a Full format of my HDD through windows, later to read that it is useless and it's just scanning for errors opposed to the quick format.
    Is there any other free software out there that can secure my drive and take less that 15 hours?
    Thanks!
  2. Kardonxt
    Kardonxt 2[H]4U
    2,968
    Apr 13, 2009
    Unfortunately it takes a long time to flip 6tb of bits to zeros, no way around that. A single pass wipe will be the fastest, mostly secure option. I believe the "quick" option in dban does this.
    IMHO start it now and just let it run as long as you can. Odds of recovering anything, even if it only makes it 1/2 way, seems pretty slim without some serious know how.
  3. ryan_975
    ryan_975 [H]ardForum Junkie
    14,180
    Feb 6, 2006
    Zero fill it. Nothing can recover that.
  4. Dracarys
    Dracarys n00b
    56
    Dec 16, 2014
    So which option? The Gutmann Wipe was going to take probably over 3 days.
  5. ryan_975
    14,180
    Feb 6, 2006
    Quick erase.
    The gutmann wipe is based on a misinterpretation of a paper written 25 years ago about very different hard drive technology.
    Dracarys likes this.
  6. Kardonxt
    Kardonxt 2[H]4U
    2,968
    Apr 13, 2009
    Like Ryan said, Quick erase. It does a full zero wipe, unlike the windows quick erase.
  7. Dracarys
    Dracarys n00b
    56
    Dec 16, 2014
  8. Dead Parrot
    Dead Parrot 2[H]4U
    2,513
    Mar 4, 2013
    Probably too late for this HD but one thing I have done is do what erasing/wiping I want to do, then install a version of Linux. Not a real security measure but might convince the buyer there isn't anything worth looking for on that HD.
  9. tedych
    tedych Limp Gawd
    372
    Jan 18, 2013
    Just copying/multiplicating a big (unimportant, maybe some movie) file to fill up the drive (in one partition that spans the full drive) would be enough if you have the time to wait it up. Simple calc results in about 10 hours to finish for 6TB.
