Self-made memory heatsink
Pizhihong
Not bad, would look much nicer if you sanded and/or wet sanded it to polish up the edges.
Thank you I have no professional tools. So there is no processing
谢谢夸奖!我没有专业的工具...所以只能要求实用性.不能让它的外观更好看
You don't need tools to use sandpaper, just a hard flat surface and some time :)
