Selective POSTing
rmnoon
I recently acquired an ECS K75SA with an AXP 1800+ from a friend with the intention of making it into a server/firewall. He claimed the AGP slot no longer worked, but he isn't the most technically inclined, so I figured I'd take a look at it.
The problem, it seems, is far more complicated.
The board only POSTs ocassionally, if at all. When turned on all the fans will spin and the CD drive would blink, but that is all. I initially thought it was the fact that I had an older AOpen 250W power supply plugged into it, but it still does it when I use an Antec 350W.
I've tried resetting the CMOS as well as replacing the battery. I've tried numerous sticks of both DDR and SDR (the board supports both) in every possible configuration. I've disconnecterd all nonessential hardware. I'm kind of at a loss, here.
I know the components work because they HAVE POSTed before, they just seem very unreliable at it. My instincts tell me that this board is fried, but I wonder if there is something that I might be missing.
Any advice is greatly appreciated.
Thanks,
Ryan
Do you have a power supply tester? Test both of them (cuase it would be rare but who knows). If all things are gone except gfx, cpu and ram...try a new CPU as that could be gone. If u did and u know the 2nd works, swap video. It can cuase problems if gfx card is bad. If you know its good, then lastly, which you prob did, put in known working ram. Then, and only then, is when you know the boards gone. Id suggest RMA'ing it if its still under warrenty, or just go 64 since its going to be a server/firewall comp. Its going to need that power.
I'd probably blame this on shoddy manufacturing, on the part of ECS. Yes, I know, they've been trying to change their ways, but early+ a few latter revisions of that board (K7S5A) have been known to be. well.. shit. Face facts. Chances are a few of the traces have shorted out due to shit soldering, or shit components.. You should pick up a cheap nf2 aopen/asus board to cradle that older cpu for now. Sorry, but ebay/newegg look to be your best option(s). atm. Fucking A, man, I've got one hanging on the wall, with a ti200 and a flawed orb. :/ sorry i couldn't help more..
-halc.
on the ps side, you've checked ps/mem(ddr/sdr), but have you changed out the vid card? also, check cables like MAD. could be a bad ata/power cable somewhere..) good luck, bro.
I've replaced with different agp/pci vidcards, as well as different power supplies...I'd chalk it to shity manufacturing, too.
Its funny cause at my hs where i work over the summer, we got those exact board for some comps (that we built) and their not that great. A few blew out, crappy, crappy sound. So most likely its the board. If its going to be a serv/firewall, id say cough up the money for a 64 system..prob an opteron since their known for their workhorse abilites.
