nameless_centurian
- Apr 4, 2003
to get a better understanding of the situation, look here
http://hardforum.com/showthread.php?threadid=712234
it still doesn't find the installtion media often- but when it does...
for some odd reason, i am getting signal 11 errors again in redhat, and segmentation faults in Vector Linux, which is based on slack.
i changed the wait states for the memory from "normal" to "8/10 ns"
i tried moving the jumper from 133mhz to 100mhz, but something is broken on the mobo. when i move the jumper to 100mhz, the machine acts as though there is no jumper present at all (i know this because i removed the jumper to see if i got similar results- i did)
i can't add any more RAM to this machine, God knows it should be plenty for what i want it to do.
i reenabled the caches i previously disabled , enabled the memory hole, disabled PnP....
i have temporarily installed Win ME...oddly enough, it worked like a charm, not a single error in the install process. but i don't like Win ME, i want to learn linux and i also have a few projects for the linux box.
i also downloaded the live cd of VL, it works nicely. so i am baffled as to why knoppix and VL live run but no distros will install.
gosh, is there anything left to do?
-edit
the cd media in VL IS found....the installation always tanks when either copying the filesystem or the kernel...never got past that point, that's when i get a segmentation fault.
-edit
