I've been saying for a while that I want to get a dual-screen setup, and I've finally convinced myself to actually buy one. I haven't looked at monitors since I bought my current one almost two years ago now though, so I could use some updated advise.
I currently have a 17" Samsung SyncMaster 710T that I'm overall satisfied with, although lately it doesn't seem to be as great for viewing text as other screens I've seen, but that's probably just a matter of re-adjusting the settings.
I'd also like a greater vertical (up and down) viewing angle than my current display - the colors become distorted on this screen if viewed at to great of a vertical angle, which gets annoying if I want to lay down and watch TV.
I'm looking for an (aesthetically) matching screen to create a dual display setup.
Requirements:
- 17" Screen
- Black
- 1 DVI, 1 VGA input [and yes, I will actually use both inputs on both screens . . . ]
- Around $200
Usage: A little bit of everything - internet, coding, television/movies, gaming, although one of the two screens will likely be used more often for multimedia than the other.
So far http://www.newegg.com/Product/Product.asp?Item=N82E16824001079 seems to be the best deal I've found, but I can't find any recent reviews of 17" screens. Any other suggestions?
Thanks
Requirements:
- 17" Screen
- Black
- Around $200
Thanks
