Hello everybody, I need some help deciding on which computer to buy
. I just landed a new job and have some extra money. The computer I'm using now is seeing the last of his days and with doom3/hl2 etc coming out I'm anxious to upgrade. I went through these forums and found what most people use for both amd/intel. I'm mostly concerned about longevity. Will both of these setups hold me over for awhile. I picked the 939pin because I heard that's what amd is using for now and the P4EE for the same reason. Right now I'm undecided about which video card either ati or nvidia top of the line.
Here's the Intel -
http://secure.newegg.com/app/WishHistoryReview.asp?position=HISTORY&submit=VIEW&ID=871983
Amd -
http://secure.newegg.com/app/WishHistoryReview.asp?position=HISTORY&submit=VIEW&ID=855344
Some concerns - psu be enough with a video card? How's the memory? Is the cooling sufficient? (I will be purchasing the Case flow fan from CM once they get in stock.) Anything additional?
I'm open for all suggestions, money is not a huge issue but I'm looking for the best bang for the buck with longevity. Let me know what you guys like or dislike.
I'm really looking forward to the new doom3 benchmarks that will hopefully come out soon. That will also reflect on the system. I haven't been able to find some good steady reviews on any mobo's with pci-e or and video cards that match. I'm willing to go with those if someone can recommend something good.
Here's the Intel -
Amd -
