Seeking feedback on gaming built
ark1
This built will be mainly for gaming and my budget is around $2000 CAN.
Motherboard : ASUS P5KC ATX LGA775 P35 DDR3 DDR2 1333FSB 2PCI-E16 PCI-E1 3PCI Sound SATA2 1394 $158.99 - Is it 45nm read? How is the OC capacity of this board? I would like to push the q6600 to +3 GHZ.
CPU: Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box $289.99 - I am still torn between the E6850 and Q6600 but I am leaning more and more towards the Q6600
Video card: EVGA E-GEFORCE 8800 Ultra 612MHZ 768MB 2.16GHZ GDDR3 Dual DVI-I HDCP HDTV Out Video Card $619.99
RAM: Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC2-6400 DDR2-800 CL 4-4-4-12 240PIN Dual Channel Memory $149.99 $149.99
PSU: Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24PIN ATX Modular Power Supply 120MM Fan 2X PCI-E $138.99 $138.99
Case: Antec P182 ATX Black Mid Tower Case 4X5.25 1X3.5 6X3.5INT No PS Front USB Audio Firewire $135.99 $135.99 - Will everything fit in this case?
HD: Seagate Barracuda 7200.10 320GB SATA2 3GB/S 7200RPM 16MB Cache NCQ Hard Drive $93.83 $93.83
CPU Heatsink : Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink $65.29 $65.29 - Will this be enough to push the q6600 over +3 GHz?
CPU FAN : Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB $18.43 $18.43
Floppy : Sony Black 1.44MB 3.5IN Floppy Drive $9.38 - Yes, I still need a floppy drive. :)
CD/DVD writer: LG GSA-H62N SATA DVD+RW 18X8X16 DVD-RW 18X6X16 DL 10X Black OEM DVD Writer W/ SW $35.99 - I chose the drive at random, would you have any recommendation for a SATA CD/DVD RW?
My current LCD is a 20.1 LG but I plan on upgrading to a 24 inches in a month or so.
Total is about $1,715 CAN and just over $1900 with taxes, shipping and insurance. I should save on top about $100 in various mail-in rebates.
Thanks for any feedback
Looks good.
Though, what will you be doing with this system? If you don't really need a quadcore right now, then I'd stick to dual core and upgrade later. Most games/apps are still trying to make use of dual core CPUs. Since you're going with a P35 board, you could upgrade to a Yorkfield chip within a year or so, along with some mature DDR3. The good thing about the yorkfields is that they're 45nm, which means they consume less power, and in turn, less heat. That all provides for better overclocking conditions.
Looks good.
Yeah I know, that is why I am torn between the two. However, the way I see it is if I can OC the Q6600 right now, I will still be able to play pretty much any game at the moment on this setup with high settings. I know, for now, the benchmarks favor the E6850 but I do not even know if I will notice the difference.
When the new 45nm CPU will hit the market it will probably be insanely expensive for a while so it looks like I won't be upgrading for at least 2 years maybe more. For your info, my current CPU is an AMD 2100. :)
Intel plans to release these chips at current dual core prices. They want to help the push to multicore, so expect them to be affordable. The 8-core chips should be the uber expensive ones.
One more thing, is my PSU good enough if I want to overclock?
It should be, since you're only going with a single Ultra.
I am having a change of heart with the P5KC (I do not want DDR3 support at the moment). I would prefer to go with a P35 board. Which P35 that is in the $150 should I go if I want to do some overclocking and would like support for 45nm?
Thanks again
Why not? Does having ddr3 support hinder the performance somehow?
Nope, but it costs more, and at the moment doesn't look to provide any performance increase. (Also, can you run DDR2 and DDR3 at the same time on the P35C-DS3R? Cause that would be unfortunate if you decided to go DDR3 and suddenly had 2 GB of DDR2 no one wanted in the future...) Also, the non-C variant costs less... but I agree, if he's still looking to spend $150 I don't see why he's changing boards.
And OP -- the P35C-DS3R -is- a P35 board.
lol... yah, thats why i'm wondering about the sudden change of heart, lol, unless he wants raid5. the p5kc has raid0/1 through jmicron since it uses only ich9, while the p35c-ds3r uses ich9, so it has native raid support.
