ArrowMk84
- Dec 3, 2005
I turned off PPL Overvoltage to get sleep to work right, and now I'm seeing up to half a megahertz of clock jitter in both the CPU and DRAM clocks (where before it was a tenth of a megahertz). I've been running Prime95 large FFT test for over half an hour now (just made the change), and I haven't seen any problems yet (I'm about to do the blend test next), but should I be concerned? Or is it normal to see this much jitter?
I've got my CPU set to 4.6 GHz, using a multiplier of 46 and a BCLK of 100. Vcore is at 1.35 (with a max temp of 79C on one of the cores when doing Small FFTs or the Intel Burn test - so I'm very happy with the overclock). DRAM is set the stock speeds of 1866 MHz, 9-10-9-27-2T. Turbo boost and speed step are off (although, speed step still acts like it's on - weird, but it saves power when idle without hurting performance). Everything else is left on auto.
Thanks!
Edit: By the way, I used CPU-Z and ASUS AI Suite II to monitor the clock frequencies, so yeah, there is some eye-balling involved.
Thanks!
