See Saturn Sans Rings
Terry Olaes
I Used to be the [H] News Guy
Well, not quite, but close. The angles of the Earth and Saturn right now gives you an opportunity to see the Saturnian rings edge-on, making them nearly invisible when viewed through a telescope. This is your best opportunity to see Saturn in this state for a while so take advantage of it while you can.
If you have a telescope, get out and take a look! Saturn will be nearly ringless for the next few months, and then the rings will start to open up once again. After that, you’ll have plenty of time to soak in the phenomenal view of the solar system’s best showpiece — the next ring plane crossing isn’t until March of 2025.
with the rings being only about 50ft thick, its hard to imagine you can see them at all if we were right in sight with them. it looks like that photo is still very slightly off... but really cool still.
