Security - Restricting to specific USB sticks
Discussion in 'Networking & Security' started by SCiFiRE, Oct 28, 2008.
  1. SCiFiRE
    SCiFiRE [H]ard|Gawd
    1,701
    Jun 13, 2000
    Hi Guys,
    really wasnt sure where to post it, so i have posted it here and in storage.
    Ive got some laptops at work, and i want to stop people from using unauthorised USB sticks. I do NOT want to restrict USB sticks completely, as it not only makes my job harder but also negates our emergency file-transfer system if our wireless goes down.
    So Im wondering if there is a method or some software that would have the laptops only accept two or three specific USB sticks (via device ID, or a certificate file, some sort of encyption even)?
    The laptops are all running Windows XP SP2
  2. Keiichi
    Keiichi [H]ard|Gawd
    1,493
    Jun 10, 2004
  3. Direwolf20
    Direwolf20 2[H]4U
    2,468
    Mar 10, 2004
    I agree with Keiichi, I can't think of anything better. Disable them all, and know how to enable them when you need to. Its better than filling all the USB ports with superglue at least :).
  4. SCiFiRE
    SCiFiRE [H]ard|Gawd
    1,701
    Jun 13, 2000
    Nah, I'd rather just leave them enabled and give the team a stern talking to about bringing in outside USB sticks. If Im not here and the wireless goes down (which i have no control over, thats the contracted IT dept), They need a quick method of transfering files or core-business will stop.
    Ive found a few software package options now that look like they do what i need.
    thanks anyway guys
  5. archivalbackup
    archivalbackup Gawd
    643
    Oct 12, 2007
    VMware ACE. Gives you exactly the control on which USB devices can / will be allowed.
  6. XOR != OR
    XOR != OR [H]ardForum Junkie
    11,572
    Jun 17, 2003
    Zen10 from novell does this I think.
    That's if you want the overhead of running zen that is.
  7. archivalbackup
    archivalbackup Gawd
    643
    Oct 12, 2007
    You may be able to do this by installing the drivers needed by a few types of USB sticks, then denying your users the ability to install new hardware / drivers. I would have to think that through for a bit though.
  8. XOR != OR
    11,572
    Jun 17, 2003
    Wouldn't work; most USB keys work with the generic mass storage driver. No additional drivers needed, and the driver loads just fine as a limited user.
  9. slowbiznatch
    slowbiznatch Gawd
    856
    Oct 24, 2001
    Pretty sure you can do this in Symantec Endpoint Security.... not sure if that's something you'd be interested in migrating to, though.
  10. mashie
    mashie Mawd Gawd
    4,180
    Oct 25, 2000
    We have some very annoying software at work that do just this. Unless the USB device you try to connect is white listed forget about using it.
