Security Appliance for Lab?
I am finally getting my lab back up and running as well as adding to it. I get to work with alot of gear at work but I want to brush up on some skills that I dont get to use as often. I am trying to decide whether to buy a Pix 501 or 515 for for working on my firewall skills. Do you have a recommendation? 501's can be bought for 20 bucks where the 515 go for 75 or more usually.
Well...a PIX is old tech which is why they are cheap. You're better off with an ASA.
+1 for ASA if you can afford it.
If not and you have extra hardware or an ESX host, you can use a software solution like Astaro or Untagle, or pfSense w/Snort.
