Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I was wondering, at work when a screensaver is up, you have to use something like Ctrl + Shift + T in order to bring you to the log in screen. Is there a way I can set that up for home use?
Uhmmm... in Windows, pressing a key would automagically kill the screensaver and if you have it set to ask for a password or to log back in afterwards, that's pretty much the default.
Windows + L locks a workstation instantly, has done so since Windows 2000 came out and all versions of Windows since. There is a way to force users to press Control + Alt + Delete (the classic "Three Finger Salute") to bring up the login prompt; that method is considered to be the most secure of all. You'd make that change in the User Accounts part of Control Panel.
