I've heard that some anti-virus software can cause GFWL to not install right which would lead to this error. So you might want to try uninstalling GFWL then reinstall it with your antivirus turned off. Of course I'm not saying this is the only solution or reason why you're having this error, but I figured I throw it out there in case you hadn't tried that yet.Finally cleared up enough HD space to install it + DLC. Got it downloaded and installed now GFWL "fails to initiate". Now going through the paces of trying to chase down the cause...
