anyone know a good 80mm fan which could be installed here which is a little quieter at higher RPM
I also just placed my order.
I hope it goes through, though! I haven't looked at the back of my debit card lately and the stupid CVV2 code is almost completely rubbed off. I can make out the first digit and can see the imprint (but no ink) of the last. The middle one had like half an imprint, so I had to guess![]()
Anywho, I also want to order an extra radiator.
Do you have to add more fluid to the system once the additional radiator is installed?
Yes this cooler is very good. It's quiet and its performance is very good. I'm idling at around 33C and my load is around 46C.
I am on a Opteron 165 at 2.7GHz and 1.4v, and since I used the $15 paypal rebate, bring the cost down to $11, there is nothing that can beat it for that price (or for $26). And since I am using a SFF microfly, I can't use any of the big huge coolers, so this is a very good deal IMO. I bought this the first day the sale started and I got it 2 days later. As I am typing this rite now, I'm at 27C (one of the colder days today)What processor are you using @ what speed? Is it worth or not?
I wonder if this would cool better on its "low" setting than my Ninja.
Many others with this system have added a Thermaltake 120mm radiator to the loop, so that much it can handleI don't know if the pump could actually support the addition of another block and radiator.
Many others with this system have added a Thermaltake 120mm radiator to the loop, so that much it can handleIt probably can handle it with a GPU waterblock too
There are too many wires, you have to connect, and it need AC power source then DC.
