Hi, I would like to connect my Server 2012 machine to a new, second network which will only be used for local file sharing with no internet access passing through this second network. My main network is 192.168.1.x/255.255.255.0. The second network will run on a second NIC on the machine with IP 192.168.2.1/255.255.255.0.
This second network is really just one other Windows Server 2012 machine which also has two NIC's; setup the same as above, but with .1.2 and .2.2 and same masks.
The .1.x network works fine, and I can ping between the two machines in the .2.x network. However, file sharing does not work. I think it is because Windows detects this network as Public and Unidentified.
Can someone help me with a solution to this?
The reason why I am doing this is because the NIC's in the .2.x network are infiniband cards that I would like to utilize for a high speed connection between the two machines for backup purposes.
Much appreciated!
Much appreciated!
