Second monitor question
jfkriege
I am looking for a second monitor to go next to my primary. My primary is a nice S-IPS for photo editing and the secondary would be for office work only. I would love to go a little cheaper on the secondary, but I am worried that the color and contrast will be different enough that it will bother me.
For any of you that have this, or have seen this, was it terribly distracting or a really huge difference? What is the current 24" of choice for the budget end of things?
Joshua
I was looking at the 24" monitors around the $350-$400 mark if I could get away with it. If I needed to I could spend a little more and go up to the $600 range, but the money is probably better spent elsewhere in my work.
My main monitor is a 30" Apple, which I love. It would be great to get a second one of those, but the budget doesn't allow for that just yet.
Joshua
IIRC Best Buy has some 23-24 inch Dell 1080p/1920x1200 models. They are around $400. Might want to check them out if you're close to a BB.
