Second Intel X-25M G2 - What to do?
hhara
I have recently obtained a Kingston SSDNow M Series 80 GB Drive which I am about 99% sure is a Intel X-25M G2 with a Kingston logo slapped on it. Everything about it is identical to my Intel X-25M G2, including the model number, firmware listed, and the look in general. Hell, even the tech specs for the Kingston drive point to the intel's tech spec sheet.
My original X-25M G2 has already been updated to the TRIM firmware. This Kingston drive's firmware is listed as "02G9" which I am pretty sure is the firmware before TRIM.
If I were to put these two drives in Raid 0 I would lose the TRIM option, correct? I could still update the new Kingston drive to the TRIM enabled firmware and run them in Raid 0, but without being able to use TRIM, right?
Ever since I have updated my drive to the TRIM firmware I have noticed a large performance decrease. Programs that I had installed before updating the firmware now take much longer to load. I am hoping though that a format of the hard drive and some type of software that deletes everything (and in the process invokes the TRIM command) will return the drive to its original state. Does that sound like it should work?
Anyways, I barely take up the 80GB as is with the few games I have, Windows 7, and my small programs. Do you think it would be wise, in terms of longevity, performance, and usage to do Raid 0 or just set them up separately?
Thanks
hello hhara,
From what i've seen the TRIM command currently doesn't function with RAID. i'm assuming you are using the raid functionality on the X58 board which would require the matrix storage controller to be installed. As of today intel has yet to updates these drivers to support TRIM over raid or even to a single drive. Hence the reason why we need to use the MS drivers if you want TRIM support with the newest firmware on single drives.
Also after you updated the firmware and started to notice the slow down, have you tried running the intel SSD optimizer?
TRIM doesn't work with RAID. So if you're getting good enough performance using it as a game drive, then I'd let it be for now.
What TRIM does is it reverses the process that slows down an SSD over time. So if you put them in RAID 0, you'd get faster performance now, but the performance would degrade over time without having TRIM to reverse that process.
I'd search on Kingston's website for your drive's latest firmware and flash it to that. TRIM is needed for SSDs to maintain peak performance.
hello hhara,
Could you link me to intel's download page for that program? Someone had suggested I try that as well. Last time I tried to find it I came to the conclusion that they had taken it down for some reason I can no longer remember. That was about 3 weeks ago.
There was a time where they took down the old version to put up the new version a short time later I think. If we're talking about the drive toolbox, it's located here:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3044&DwnldID=18455&lang=eng
But remember guys, even with TRIM, the performance of SSD's degrade with time. After every 2 months (I prefer every), you should do a secured format (forget its name exactly) in order to ensure you have optimum performance. It shouldn't be a problem either, because you shouldn't be storing much on these except the OS and some programs.
Question,
is that needed if you run the optimizer on a regular basis as intels instructions show once a week?
Secured format? Could someone expand on this? I keep reading everywhere contradicting views on how to clean the SSD in order to get the best performance. Some people say you should run some program that completely erases everything, some say you should format it (which is wrong), and then there are other suggestions...
Basically, I had installed W7 on pre-TRIM firmware. I updated the firmware to TRIM enabled. What I want to do is the equivalent of a format on a mechanical drive, but on this SSD. I want to start over clean. What would be the best steps to take in order to get the best performance from the SSD?
If you already have the newest TRIM-supporting firmware, I would do a secure erase using HDDErase. Optionally, you could run the Intel Toolbox to optimize the drive every now and then but I think that's pointless for Win7 users as the TRIM command is issued automatically.
If you're really paranoid or anal about performance degradation, you could follow Zetherin's advice and secure erase the drive every month or two but that's not something I'm willing to bother with. The firmware on these drives does a pretty good job of minimizing performance degradation (that was the whole point of GC/TRIM).
With trim command available, this hardly provides any benefit for a good SSD. I think you're confusing usage of the SSD vs. filling up it up. SSD performance degrades mostly as you FILL up the drive due to the increased frequency of the overwrite penalty. Thus, the more stuff you put in it, the slower it will get for writes. Read speeds are not affected by this.
Instead, for maintenance purposes, I recommend using a utility like Crap Cleaner to delete temp files, caches, and bad registry entries.
See Anand's article here for details:
http://www.anandtech.com/storage/showdoc.aspx?i=3531&p=8
