I recently purchased a laptop that had a spare harddrive bay.
I installed a new SSD and installed Windows7 on it, and it works like a champ.
However, although the BIOS is set to boot from the SSD, it will occasionally try to boot from the old harddrive, and I have to go into the BIOS to fix this.
I may just swap the SSD into 0 and harddrive into bay 1 to see if it helps, but I noticed DISK0 (the old harddrive) has a system reserved 100mb on it. I assume this is from the old Windows install and might be causing issues.
Could that be the issue, and how do you kill it? In the attempt in disk management I get the error
"Windows cannot delete the system volume on this disk"
