Oct 3, 2010 #1 I icor1031 [H]ard|Gawd Joined May 29, 2010 Messages 1,295 What's the least ghetto-rigged way to put a second fan on my S1283?
Oct 3, 2010 #2 S Skull_Angel [H]ard|Gawd Joined May 31, 2010 Messages 1,664 I'd say reusable zip-ties are considered high-class ghetto rigging material, haha.
Oct 3, 2010 #3 C cn06 Limp Gawd Joined Mar 9, 2010 Messages 421 http://www.langtoninfo.com/showitem.aspx?isbn=4712477310648 These are what came with your S1283 right? If so, getting another set for push/pull should be the least ghetto way to do it.
Oct 3, 2010 #4 I icor1031 [H]ard|Gawd Joined May 29, 2010 Messages 1,295 Thanks CN, but those won't fit on the other side because it's not slotted for them.
Oct 3, 2010 #5 I icor1031 [H]ard|Gawd Joined May 29, 2010 Messages 1,295 Skull, better idea than what I had, rubber bands... Just need a vibration damper then.
Oct 3, 2010 #6 C cn06 Limp Gawd Joined Mar 9, 2010 Messages 421 Oops, sorry. I never realized the S1283 was asymmetrical. http://www.frozencpu.com/products/6507/fss-24/120mm_Black_Rubber_Fan_Silencer.html?tl=g7 Would putting this between your fan and your CPU cooler work for your dampening needs? Last edited: Oct 3, 2010
