Seasonic PCI express cable
Liver
I have a Seasonic modular power supply and I also have a ATI 4870 graphics card. The 4870 needs 2 6 pin PCI express power cables hooked up. The power supply has 2 6 pin PCI express outs.
I only have one 6 pin PCI express (to 6 pin) power cable. It is sleeved and looks quite nice. Where can I get another? I have been googling in vain.
Currently I have it done via a 4 pin molex, but that does not look as slick.
If I'm reading your post correctly, are you saying that your PSU has connections for two 6-pin cables but you only actually have one of the cables? If so, try getting in touch with Seasonic and see if you can get a second cable from them.
that is 100% correct. was wondering if there is another store you can recommend to buy the cable. as it were, i have contacted seasonic.
Aside from getting one direct from the manufacturer, I don't know of any place to buy extra modular cables.
and the email i sent to seasonic has been returned, no such domain.
