Im not sure if they go by serial number or if its receipt based. Then again who the hell keeps a receipt for 10yrs? If its been registered with someone you may need their help in getting the rma started but i cant say for sure. I can say if it can be done EVGA will do it for you. They have probably the best cs in the business.Thanks for the input. Does Evga warranty cover 2nd owner? I assumed it did not. Will find out.
That is some great information. Thanks! I had no idea.Go with 1000 watts for the Seasonic. There are issues with the TX-850 and OCP tripping from 3090 cards. I have a thread about it. It is not clear yet exactly what the problem is but Seasonic's wattage calculator recommends 1000 watts now, I believe. I might have resolved it by RMAing my TX-850 but I won't know for sure for a few more days. They may have implemented a fix or maybe I just got a bad unit but there are reports on various sites about compatibility issues with TX-850 and TX-1000 PSU's OCP being tripped by transient spikes from the 3090. It isn't that the PSU is faulty per se, it seems the OCP protection is just too sensitive for the 3090.
I would RMA the EVGA if you can, however. My advice for anyone who thinks their PSU is not playing nice with 3090 is to RMA it and if the issue appears again, then look into stepping up to a new unit and get as much power as you can reasonably afford.
