Searching for awesome FP for gaming.
Kritter
Can anyone point me in the right direction?
No dell/Apple please, heard too many bad things about these displays.
Viewsonic VX924. look it up on newegg. Good reviews. 4ms response time or something ridiculous like that. Toms hardware also did a review on it. I'm too lazy to post the links for you.
ok, you said AWESOME
http://www.sonyproductinformatie.nl/200502/nl/detail.php?product=VPLVW100
VPL-VW100
Device Home Cinema Projector
Projection System 3 SXRD panels
1 lens system
LCD Panel Size 0.62-inch
Screen Format Full HD
Resolution 1920x1080x3
Brightness High 800 / 400
ANSI Lumens Standard 1050 / 680
Contrast Ratio 2000-8000:1
Max. Input Signal Resolution Full HD
Lens Standard zoom 1.8 times (man)
Fan Noise Lamp mode std 24dB
Lamp mode high 33dB
Keystone Vertical •
Correction Horizontal -
HDTV / DTV ready Full HD
Lamp Type Pure Xenon 400W
Life H High/Standard TBC
Replacement LMP-H400
Screen Size (diagonally) 40 - 200 inch
102 - 508 cm
CONNECTORS
D sub 15-pin -
Composite Video •
S-Video •
Component Video •
HDMI / DVI •/•
USB -
RS232C / CTRL S •/-
5BNC -
Ethernet RJ-45
Trigger out • (12V)
Filter Cleaning Time (Hours) TBC
GENERAL
Dimensions (wxhxd) in mm 500x590x170
Weight (kg) 17 kg
Power Supply (V) 220-240V 50Hz
Power Consumption / Standby (W) TBC
OTHERS
Throwing distance 80"/2m screen TBC
100"/2.5m screen TBC
Supplied Accessories Remote Control •
Replacement Air Filter TBC
Ceiling Mount Bracket (optional accy) PSS-610NL
* Depending on which lens is being used
SONY SPOTLIGHTS NEW SXRD 1080P HOME THEATER FRONT PROJECTOR
INDIANAPOLIS, Sept. 8, 2005 - Sony Electronics today took the wraps off a new 1920 x 1080p (progressive) high-definition front projector based on the company's exclusive Silicon X-tal Reflective Display (SXRD™) technology, with a contrast ratio of up to 15,000:1.
The VPL-VW100 joins the two new Grand WEGA SXRD rear-projection microdisplay televisions, the KDS-R60XBR1 and KDS-R50XBR1, utilizing the world's smallest 0.61 SXRD chip to deliver more than 2 million pixels and the full power of high-definition. The projector incorporates three SXRD chips - one each for red, green and blue color reproduction - to deliver more than 6 million native pixels.
"Our goal is to optimize the home theater experience and this new SXRD projector is another example of how we're accomplishing that goal," said Randy Waynick, senior vice president of the Home Products Division for Sony Electronics. "This is absolutely a true movie theater experience in the comfort of your own home."
Leaning on some of the same technology found in Sony's acclaimed QUALIA 004 SXRD projector, the VPL-VW100 model features a 400 watt Pure Xenon lamp that delivers unrivaled color reproduction. The lamp approximates sun light and can reproduce colors closest to the natural spectrum including the red bandwidth, and is widely used in professional film projectors.
The new Advanced Iris produces accurate blacks and works with three 0.61 SXRD chips to deliver an over-all contrast ratio of up to 15,000:1 when "auto" Iris mode is on. Additionally, thanks to an advanced cooling structure, the VPL-VW100 features an extremely low fan noise of 22dB, which is one of the lowest in the industry and critical for home theater applications.
The projector also features 1.8x powered lens zoom and powered focus as well as lens shift to adjust the vertical and/or horizontal manual location of the image for flexible installation locations. Input options include 1080p HDMI and DVI-D and RGB and component video.
The new VPL-VW100 will be available in November for about $10,000 at authorized dealers nationwide.
I was skeptical of the 2005fpw b/c of all the people bitching about it. Bought one and I absolutely love it. I have the L90D+ too. Widescreen only for me forever :)
