Searching for a P4
general
Being able to actually search for the string P4 when you're looking for a processor would be great.
I'm sure MD will give you the lowdown.. but what about doing a search like
Pentium p4
as the search string? or intel p4
Try P-4 or "P-4"...it gives you a little bit of everything, but the P4 threads are there also.
How about adding it to the search function in admincp ?
AdminCP / vBulletin Options / Message Searching Options / Words to be Included Despite Character Limit /
...and there add words like P4 and X2.
P4 is kinda a bad search anyway.
What exactly are you looking for? Maybe try a motherboard name, a problem you're having, "intel overclocking," etc.
agreed, or make a thread. or do you just want to read about pentium 4s? :p
To buy one? The problem is you'll also hit every post by everybody who's put "P4" (or whatever you decide to search for) into their signature. There's no workaround for this; unfortunately, and it makes the search feature nearly useless here.
forum searches don't return information in the sig :rolleyes:
W00t! When was it fixed? I remember giving up on search here last summer because it hit signature contents.
if you're looking for a p4, you might want to look in steve's iguana's belly. :D
