searched still slightly confused amd overclock
1100t 3.3 stock
990 xfa ud7
16 gigs corsair vengeance 88824 1600 mhz
msi lightning extreme 580 3 gb model
ocz 60 gig vertex 3
950 corsair txw?
9900 max zalman
xp64 yes i know old school but i like xp a lot more then vista or 7
upgraded from an old 754 3200+ msi board with a 6200gt agp i said screw it got the best possible
im new to overclocking and trying really hard to understand all the new terms
using the amd overdrive utility has been helping a lot however a few questions still persist
first issue my vdda25 core is suppose to be 2.5 volts it shows -5.180 ???
second issue the fan control dont seem to be working on manual control option
third issue it keeps resetting my pcie to 60 mhz
what is the vdda25 core? my google fu is failing me
if i lowered my ram to 1333 with same cas then bumped up the reference that could bring my ram back up to 1600 still being stable ?
the turbo core is 3 cores at 3.7 at 1.45 and stock is 3.3 @ 1.325 im assuming thats a very stable amd clock. so far im up to 3.8 @ 1.35
42 idle 54c loaded
im hoping to hit 4.0 call that perfectly fine.
does it really matter if everything is 200 1000 2000 or is like 207 1035 2070 acceptable ? if that makes sense?
thankyou
I've only ever OC'd through BIOS/UEFI I can't help you out, though I can say that you seem to be taking an appropriately cautious approach. AMD 6 core parts are much hotter than their 4 core parts. Remember: anything over 60c is dangerous.
Same as above, only used BIOS/UEFI. I don't trust software overclocking tools. They use too much voltage, you don't get the best clocks possible, and for fucks sake turn turbo core off. Unleash the power of all 6 cores and whatever you're not using let them fold!
(1090T @ 3.7GHz w/1.33v, turbo core off, 38c under an H50 with p/p ~50cfm fans)
Also, don't bother OCing the memory. There is such a small difference between 1333 and any OC'd clocks that it just isn't worth your time. Keep the timings tight and you'll be fine.
Overclock using the bios.
The only things you should be concerned with with a BE chip is CPU voltage, CPU multiplier, CPU-NB multiplier, CPU-NB voltage, and HT-link.
CPU voltage and multiplier are pretty self explanatory. Either set a multiplier you want to reach and increase voltage until it's stable (making sure it stays under ~65-70 C, the Thubans have a higher heat ceiling than the original Denebs), or set a maximum voltage and increase multiplier until it becomes unstable, then back off on the multiplier.
CPU-NB is the same. 2400 mhz is the maximum speed without voltage increase, and increase the voltage for higher speeds. Higher CPU-NB speeds greatly increases the responsiveness of a Thuban system. Usually maxes out around 2800-3000 mhz.
HT-link: Manually set this to 2000 mhz. Higher speeds are not needed, and only leads to unnecessary instability.
You should disable Turbo Core until you get it stable, then re-enable it if you want.
Use something called PhenomMsrTweaker. It allows you to set custom P-states (lower clocks and voltages when idling). It can also let you set a custom Turbo Core state (4 cores instead of 3, etc).
like tsumi mentioned, always use the bios to overclock with.
since its a BE use the multiplier and CPU voltage. also change your CPU-NB multiplier so that the NB is at 3000mhz(3Ghz) once you finish finding your stable CPU overclock. you may have to increase the CPU-NB voltage but probably won't have to go any higher then 1.35v on the CPU-NB. it will give you a decent performance increase.
remember to turn off turbo when overclocking as well. theres no reason to have it on once you exceed the turbo clock speed as your base clock.
tips to remember.
keep the stress test temps under 70C (doesn't matter if it gets really close to 70C since you will never hit those temps with anything else other then stress testing applications)
keep the CPU voltage at 1.55v or lower.
max CPU-NB voltage is 1.55v as well.
the way i typically overclock unlocked AMD processors as long as you are using aftermarket cooling is setting the cpu voltage to 1.45V and increasing the CPU multiplier 1 step at a time and running 5 passes of intel burn test between each one. once the processor becomes unstable i can either increase the CPU voltage if the temps are low enough to 1.5v and try pushing the multiplier higher. if the temps are to high then i drop the multiplier down one and then see how low i can drop the voltage and keep it stable.
