search question
renswic
is there a way to search by phrase? atm when i search "Sennheiser HD201" it shows up as Search: Key Word(s): Sennheiser, HD201
and i get a great number of posts, come with jsut one of the words, some with both its rather tireing to look threw a post only to find out it was made for a different item
what are the odds of some other computer related piece of equipment having the model # HD201? Why not just search for that and leave out the Sennheiser? I think that'd work.
It's a 'key word' search and not by phrase. That's the way this software works. You actually may hit the correct phrase if that is how the thread title was phrased.
Narrow your search down as much as possible and your chances of getting a hit are much higher.
Usually if a thread contains both key term, the thread will appear at the top. Threads that contain only on appear farther down. If you look at the first few results, you should get what you seek.
heh guess i should be searching on how to fully use my brain, didnt think to just try the model number
