Ok I'm wondering is there such a thing as a sealed WC system. what i'm after is a very low maintance Sealable system that could possibly be turned upsidedown and put on it's side without leaking.
I would AT First like teh ability to fill it but after that i want to be able to seal the tank closed and never really have to worry about it again. Is this possible or am i asking the impossible. I mean if the system is air tight no water vapour can escape. hence i should have no fluid loss ?
Or should i just keep saving and get a promethea/vapochill.
