Josh Hazel
- Aug 27, 2006
I was curious what others found in performance of there Seagate 8TB drives...
This was the best review I found here Seagate 8TB review
I would tend to have to agree with the review. It does surprisingly well writing in short bursts. My initial calculations were in the 100s of MB/sec. Obviously that decreases significantly after longer periods of data transfer.
Just thought I would share my real world transfer rates with everyone... I decided to backup 7TB from one drive to the next. I used a 2 brand new drives and only used quick format.
I am running both drives on the same ICR10r chipset. Both drives and ports are SATA3.
After 1 hour 7 minutes of transfer from one 8TB to another 8TB I had transferred 339,501,514,752 bytes. I am estimating that to be ~80.54 MB/sec transfer between the two if my math on the above is correct (I am sure someone will tell me if I suck at math).
After 2 hour 24 minutes I checked again 507,157,143,552 bytes estimating: 55.97948405 MB/sec
After 13 hours 0 minutes I checked again 2,270,946,021,376 bytes copied, estimating: 46.27655758 MB/sec
After 20 hours 20 minutes I checked again 3,389,091,655,680 bytes copied, estimating: 44.22673328 MB/sec
After 40 hours 12 minutes I checked again 6,501,294,723,072 bytes copied, estimating: 42.8421628 MB/sec
After 45 hours 13 minutes I checked again 7,204,584,013,824 bytes copied, estimating: 42.22484473 MB/sec
5 Hours remain before finishing the backup.
