Well I've added 3HDs to my Raid5 array, at first the HD on channel 8 would drop out of the array while building the array. Thought it was a HD problem and took it out. Now the HD on channel 6 is dropping out. I'm not sure why they are having problems and wondering if anyone can help. I'm using a RocketRaid 2220. I originally had 5 disks in the array with no problems. One thing that I noticed with these new HDs is that revision are different, the original ones are 3.AAC and the new ones are 3.AAK. I have Read Ahead, Write Cached, and NCQ enabled. Sata150 mode. I'm going to go ahead and pull the disk off of channel 6 and see if only adding 1 new disk will work. Any other ideas would be great.
Edit forgot to mention they are all 7200.10 400GB
