I just bought five ST2000DL003 with the intention of using them in a RAID array. Because I'm using an Areca ARC-1261ML which can do sustained sequential transfers up to 840 MB/s (maybe even faster — I haven't yet had the opportunity to max it out), the slowest drive among these is going to govern how fast the entire array can be (in sustained transfers). So how fast each one is important to me.
I ran a full test in HD Tune Pro 4.61 (full version) on each drive (the full test took just under 5 hours on each drive, but generates a very nice neat graph). The results were very interesting — and then when I viewed all five results at the end, the results were stunning. It turns out that sorting the drives by average transfer rate is identical to sorting them by serial number!
I think it would be unwise to share the full serial numbers, but the first one is 5YD31xxx and the last is 5YD36xxx. I was so stunned by the result that I double and triple and quadruple checked; they are definitely in order by their average sustained sequential transfer rate. Note that since Seagate ST2000DL003 serial numbers are alphanumeric, the sorting is done with 0-9 first followed by A-Z; the slowest drive is the first in the sort with the earliest (lowest) serial number, and the fastest drive has the latest (highest) serial number. The chance of this happening randomly should be 1/5! = 1/120... pretty slim odds of this happening by chance.
There are some minor sources of error, for when I was multitasking and reading some files on other hard drive volumes it interfered a little bit with the test (slowed down transfer rate a little in a particular point of the graph — notably towards the end of the test of the first drive and third drive) but this should affect the average by <0.1 MB/s.
All five drives are divided into 17 transfer rate zones, and the dividing points between zones are the same on all five drives.
I have ordered seven more of this same model drive from a different place. (The plan is to put 12 of them in a RAID 6.) When they arrive it'll be most interesting to see if they fit into the pattern. At the moment I'm not entirely convinced this didn't happen by random chance, but if all 12 drives fit into the pattern there will be no disputing it.
BTW sample variation is not specific to Seagates... I've seen it in Western Digitals as well; among the same model and firmware, the zoning pattern itself is subject to variation, as well as the average transfer rate.
Here are all five, sorted by serial number (from lowest to highest, top to bottom):
(ignore the CPU usage — that seems to vary based on if I'm multitasking at the time the test finishes)
