Having horrible luck with these SATA drives!
First one died within 1 year. Second one was DOA. Third one died overnight after about 3 months with lots of read errors on test somehow. This PC is never moved, sits in the basement off the ground and runs cool. 5 case fans too. The other WD drive in there is a rock and has been with me for several years.
Am I simply having bad luck or are these drives subpar? I am under warranty still and almost on a first name basis with India support but jeez... What could be causing this pain? Could some incompatability be causing read errors and physicaly damage to the disks?
I have an Asus K8N-E mobo using the Nforce3 250 chipset. I have the drive using the straight SATA master #4 connector, non-raid with the Nvidia sw-ide driver... XP-Pro.
I am writing this email as a cry for advice or warning to others, depending on the outcome.
-bamazeen
-bamazeen
