mek_nginear
- Oct 25, 2006
I just purchased and installed a brandnew Maxtor (cough, cough... SEAGATE) hard drive that I received from Fry's/Outpost. Though branded a Maxtor, it was definitely a Seagate ST3500630AS DiamondMax 21, Series 3.5, 7200.10 (only difference is "STM" instead of "ST" in the ID string).
What is interesting is that this hard drive runs SIGNIFICANTLY hotter than a close equivalent Samsung 400GB SATA II HDD (also 7200rpm, and also containing 16MB cache, just not perpendicular recording). According to Speedfan and S.M.A.R.T., my new MaxGate drive is idling at 44C, while a 400GB Samsung T166 HD403LJ, when positioned in the same bay, is only 32C (I swapped them to check). The 7200.10 drive is uncomfortable to the touch.
Plus, after only 2 days of usage, the two Speedfan suitability/reliability evaluations of the 7200.10 have both dropped to 92%. I've been using the Samsung similiarly (purely as a storage drive) for almost six months, and its ratings are both still 100%. I just transfered almost 300GB of files from an old SATA I Maxtor (pre-Seagate takeover) 320GB drive to the new drive and now I'm getting a little concerned.... Note that the old 320GB Maxtor drive also is still rated at 100%!
BTW, the 7200.10 requires four 125GB platters to reach its capacity, while the Samsung uses only three 167GB platters (obviously part of one platter isn't being used for the 400GB model, the 500GB HD501LJ uses the full three platters).
Guess whose drives I'll be exclusively buying in the future? And..... are these "MaxGate" drives a failure just waiting to happen?
