Seagate 400GB - Problem
Dps
I recently bought a ew seagate 400GB EIDE HD 7200/16MB/ATA-100 for my computer..
I have a Abit NF8V motherboard and a AMD 64 2800+ and 1.25gb of ram
the problem I am having is I can get other hard drives to be read as the master, but when I
connect it to either the blue or grey or black or grey ide cables it only reads as the
slave.
I swapped my ide cables and the cd rom continues to be read as a master but the seagate 400gb hd will only be read as a slave. I changed the cables from cable select to master on both ide cables.
I swapped the hard drive with my old maxtor computer and it was able to be read as a master my main problem is I have the 400gb which I want to be read as a master so I can add my additional slave hard drive. I don't know why I can't get it to be read as a master.
Please help me, give me some suggestions and some support as I have tried everything I know,please tell me your input and I will let you know if I have tried it and hopefully one of
you can save me from this problem!!
Thanks,
Check for a BIOS update.
See ABIT's site for your MOBO and the size of drive it can handle.
If nothing is listed contact ABIT support.
have you tried setting both drives to cable select? <dons flame suit, yea i know its bad technique>
