Seagate 160 Gig drive
Lestang
Has anyone had an issue with seagate drives and win xp pro. computer only sees 127.5 gigs
total. The drive says 160 gig on the outside of the drive. I have an epox 9nda3j mb also.
I had this problem too.
When I was in the process of installing Windows, it showed the drive as 127GB.
Once I installed XP Pro and SP2, the drive showed up correctly.
I would just partition some of the drive, then make more partitions once you have SP2 installed.
maybe I will try that. I will have to delete the extended partition and reboot maybe windows will see the rest then.
