It should. Are you going to buy the card or do you already have it ? Because if it is not for gaming, I'd recommend something else, like a cheaper Radeon HD 4xxx card or Nvidia Geforce 9500 series. They cost about the same but are newer and use less power.
not for gaming...its gonna be for a music setup to run dual monitors. my main concern is the power since i think my bros shuttle is only like 250w oh also needs dual dvi
Then I'd recommend something like the cheaper passively cooled cards like:
Asus EN9400GT SILENT/DI/512MD2
or
Asus EAH4350 SILENT/DI/512MD2
Both are passive, I just choose Asus because it was the first on the list But these cards don't use a lot of power, support multiple screens and still do 3D and video decoding so you got everything you need and they are cheap (30-50$)
