Scythe Shogun
ColStripe
Anyone out there running this beast? I was thinking of grabbing one and slapping a 120mm X 120mm x 38mm fan on it. I sent Scythe an email asking if it could handle the 38mm depth days ago, no reply. Anyone know if it can handle it with provided mounting hardware?
If it uses the same wire clips the Ninja comes with, then no the 38mm fan won't work (not that you can't rig it). To secure the 2nd 120mm fan to my ninja, I used a 120 - 92mm fan adapter (20 the fan blades wouldn't hit the hs fins) then used the ground wire from some 12ga romex wire to tie it on :D
