http://www.newegg.com/Product/Product.asp?Item=N82E16835185001
Scythe SCNJ-1000P
I got the hs to replace my stock amd opteron dual core 165 socket 939 cpu. The temps with the stock was like around 48c load. With the new hs with artic silver 5 is now like mid 59's c without fan and like low 50's c with stock fan. Tried reinstalling it second time with less termal compound. Using the termaltake tusnami full tower case with 120mm stock case rear fan and intake. I did have trouble installing it, i moved the hs a lot while trying 2 install. What did i do wrong or is it just crap hs?
Scythe SCNJ-1000P
